Bug/Missing Feature with batch rendering
zboog
I've noticed the unfortunate feature of Octane in batch rendering - unless you manually create all the directories, the render is processed but never gets saved anywhere.
For instance, if I set up each of my render layers to save out a different filename and file path I have to make sure I go into Windows explorer and create empty directories for all the layers. Otherwise, nothing saves out.
Return to “Autodesk Maya”
