OctaneRender™ for Blender 1.55 - 5.2 Win [OBSOLETE]
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Fixed bug: crash on Linux during changing of some material attributes.
  • Fixed bug: wrong dispersion coefficient loaded into server from Specular material.
Blender Octane Edition - 5.2 (2.71.5) (64.7MB autoinstaller file)
Octane Server - 1.55 - 5.2 (8.2MB autoinstaller file)
DEMO is now available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 1.55 - 5.2 (7.0MB autoinstaller file)
Omnitrix
I have some question.
Is there way to convert maeterials/textures from Cycles/Internal to Octane Renderer?
There is scene with ~70+ materials with textures(for Internal/Cycles), and I need to convert this for Octane :/
Synthercat
Check the blender addons there is only one material addon that does get the job faster (hotkey Q if I remember it right)
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
simdal
Omnitrix wrote:I have some question.
+1
thanks,
Simone
Win 10 64, 4xGTX780ti 8xTeslaK80, Octane, Blender, Archicad
mib2berlin
Hi, there is a BI to Cycles converter addon.
May you can find a python scripter to rewrite it to Octane materials but it is a lot of work I fear.
http://wiki.blender.org/index.php/Exten ... _to_Cycles
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
Stelios20
Hello everyone,
I am really confused with Octane for blender. Could someone tell me in a few words, how can I export
a scene with materials and maps to Octane Standalone? Also, does octane support particle hair system?
Do I need to set an object or group as instance in order to make it work?
Thank you in advance for your time!
Win 10 | i7 3770k | 32 GB ram | 1x Gtx Titan 6 GB | 2x Gtx Titan X 12 GB
aLeXXtoR
Stelios20 wrote:how can I export a scene with materials and maps to Octane Standalone?
You can't. You can export alembic (for animation) or OBJ (for static scenes) and set your materials in Standalone.
Stelios20 wrote:Also, does octane support particle hair system?
This is 2.0 feature. Currently it works if you use Mesh object as a particle type.
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
Stelios20
Thank you! So if I want to export a carpet which consists of a scattered object, I have to convert it to mesh?
aLeXXtoR
Stelios20 wrote:Thank you! So if I want to export a carpet which consists of a scattered object, I have to convert it to mesh?
You don't need to convert it. You just have to set paerticle type to "Mesh" and set some simple mesh (e.g. small thin-long plane) there as the mesh object (don't forget to set Octane mesh type to "Scatter" for it).
You can also make your carpet using Displace feature in some cases. ;)
WebSite
Showreel
Stelios20
Thanks again for responding so fast!
I think I understood :D
Return to “Blender”
