OctaneRender™ for Blender 1.55 - 5.1 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Fixed bug: material ID mapping was shown differently after every full frame refresh.
  • Fixed bug: material preview icon rendering caused crash.
  • Fixed full material preview scene.
  • Shader Groups now work if connected to Octane nodes.
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v5.1 Linux (111MB autoinstaller file)
grimm
Hey Jimstar,
Still sadness, OctaneServer still crashes when I try to edit a node in render mode. :( This is with the default cube and when I try to turn off smoothing or change the color.
./OctaneServer
OctaneServer v. 5.1
Octane: LiveDB cache refresh started...
Octane: LiveDB cache refresh complete
ERROR: Program executed illegal instruction.. terminating
Thanks for adding in the Ctrl-C option for killing OctaneServer, much nicer now. Blender doesn't report any errors, except the normal ones because I killed the server.
./blender
Read new prefs: /home/jason/.config/blender/2.71/config/userpref.blend
found bundled python: /home/jason/graphics/OctaneBlender1.55/OctaneForBlender/usr/local/OctaneBlender/2.71/python
Octane: WARNING: only node-textures are supported
Octane: ERROR deleting material.
Octane: ERROR loading node.
Octane: ERROR loading camera.
Octane: ERROR clearing render server.
Saved session recovery to '/tmp/quit.blend'
Blender quit
grimm wrote:Still sadness, OctaneServer still crashes when I try to edit a node in render mode. :( This is with the default cube and when I try to turn off smoothing or change the color
How did you install it? Are you sure, that the liboctane.so and octane.dat in /usr/lib are both from this release?..
Synthercat
Same like 5.0 :
1. Change the material (for example smooth turned off) while live viewing as rendered result : crush
2. Turning to live preview immediately after startup, result : that blank render screen that says in the top
section that message something like 172.0.0.1 not found (If I first press F12 and then turn to render view it works)
3. Just reinstalled 4.9beta, viewing in render mode works many times faster. For example while rotating the 3d view in rendered view
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
grimm
I usually install in a directory in my home dir with the -e option and then copy the files in lib to /usr/lib:
sudo cp * /usr/lib
Thomas and I are working on another issue with stand alone and the subdiv stuff not working on my system that he said might be related to my graphics card (GTX 460). Could they be the same issue?
Edit: looks like Synthercat and I have the same issue so maybe it's Linux Mint or something else?
mib2berlin
Hi, I have the same problems with preview.
Server crash if I change color in preview render with/without border for Octane Diffuse Material for example.
Same with change from diffuse to specular.
Alll with default cube.
If I stop the preview, change color start preview again it work fine.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
grimm
Well I upgraded to the 340.32 version of the Nvidia driver but no help with the server crashing when changing the material node. :(
There is a different reason of this, not the driver. Already fixed it. Will be released soon in 5.2.
grimm
Excellent, thanks Jim. :D
Next version HERE.
Return to “Blender”
