Feature request
Xipomus
When you normally render with the plugin.
You postwork the image like with the hotpixel settings.
Is it possible for the animation tab to have that option added to it?
So that if you render an animation before it saves, it changes the hoxpixel value to the one you set and then continues with the next frame.
That would remove a lot of white noise on bigger images and make it easier to have a machine render continues for a while.
Thanks in advance for answering.
Hi
When you render an animation, the Settings tab with the Imager sliders is locked - and that is to ensure that you don't change any settings when will cause half the animation to be rendered with one set of Image values, and the other half with a different set of values. If hotpixels are an issue - set the hotpixel removal slider to 0 (ie. "full") and set caustic blur to 1. Should be almost impossible to get hotpixels with those settings. You can also reduce the GI Clamp in the kernel settings.
Xipomus
Thanks for the tip.
Will try what effect it has on the renders.
Hopefully we can limit the amount white noise with this on animation.
Coz render smooth animation and having to stop.. change hotpixel. save.. then next render is a pain.
Cheers
Return to “Poser”
