Hello all,
I am sure that I am missing something, however when I render multipass the frames are black. I have diffuse, specular, GI, reflection and light passes enabled.
Running R15 w/ 2.0.6
340.52 WHQL
Black frames with multipass
- mossberg385t
4930k @ 4.4ghz | 2x EVGA 980 Ti Classified @ 1490mhz | EVGA 1300G2 | Gigabyte x79-UP4 | 250gb 840 EVO boot | 128gb 840 Pro cache| ATTO R680 | G Speed eS Pro 8tb
Cooling: 2x EK FC780-Classy GPU Block | 2x XSPC AX360 | XSPC Photon D5 170 | XSPC Raystorm
hi, octane has not these passes. Plugin can produce depth,matid,shading normal,uv, ao of Octane. Other passes will be handled by standard render. So it's normal to see black. We are waiting a update for full set of native passes
- mossberg385t
Thank you for the prompt reply. Is this a result of Maxon or Otoy? Would I be able to use a legacy version of either software to get the passes?
If you check infokernel, you'll see which passes are available in Octane. It's limited with this option ATM. As i said, a improved version is coming for full passes in near future.
