Hi Karba,
A minor bug.
Case:
Master scene has xref files containing geometry.
Geometry in xrefs has visibility of some objects on and off.
If visibility state is changed in the Master:
Octane frame buffer: Good, as expected. respects the master file object visibility
Max frame buffer: Good, as expected. respects the master file object visibility
Network render Max frame buffer: Incorrect. Master file's object visibility is not respected. Only the xref object visibility state is rendered.
Expected behaviour:
Visibility states of objects in the master file should take precedence over xref object visibility states for network rendering as happens with the other frame buffer scenarios.
N.
layer/object visibility / xrefs
C. RAM Capacity (i.e. 6 GB)
That is deep. Not sure I can figure out what problem is.WhaleHunter wrote:Hi Karba,
A minor bug.
Case:
Expected behaviour:
N.
