OctaneRender® for Maya® 2.06 - 4.6 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2014 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
Installation:
DOWNLOAD
OctaneRender for Maya - v4.6 Linux (15.5MB autoinstaller file)
Yours,
The OctaneRender™ Team.
JohnMesh
Thanks a lot for having this on linux. Im proud to be a part of it.
JohnMesh
As i really like to keep my maya installation and also my linux environment as clean as possible i wanted to ask if there is a way to install the maya plugin as a module with a *.mod file?
I tried the following:
1. extracted the .run package only
2. made a directory /usr/autodesk/maya2014/modules/OctaneForMaya/
3. copied liboctane.so and octane.dat to /usr/autodesk/maya2014/modules/OctaneForMaya/lib
4. copied OctanePlugin.so to /usr/autodesk/maya2014/modules/OctaneForMaya/plug-ins
5. made a simple module file called OctaneForMaya.mod including these entries:
+ OctaneForMaya 2.06 /usr/autodesk/maya2014-x64/modules/OctaneForMaya
PATH +:= lib
But if i try to load the plugin i get the following error message
// Error: line 1: liboctane.so: cannot open shared object file: No such file or directory (OctanePlugin) //
Is the path /usr/lib64 hardcoded to find the libraries?
Next version HERE.
Return to “Autodesk Maya”
