Projector
zackyd
I am trying to create an actual projector in Octane. I would do this in C4D with a image in the transparency channel in front of the light. I am failing to achieve this by putting an image in the opacity channel as it is only for grayscale, Anyone have any advice on this?
4x GTX 780 6gb // 32gb ram // 1600w
hi,
funny, i was playing yesterday with a projector.
my approach, was to re-create a repro-camera, basically a box with a little hole that works like a thin-lens. then there is a plane with the normal pointing to the hole and a diffuse material with texture emission active. i have prepared a simple xpresso for controlling the aperture and the distance of the emitter from the hole and it works pretty well ;)
if you want i can share the file, it's not perfect but it works ;)
also, you can use arealight well.
gueoct
Try this method; it´s much faster and more precise:
http://render.otoy.com/forum/viewtopic. ... 54#p202254
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
no need all this tricks. Just use a image on arealight's material. try spherical projections or others. i can't remember well which was good, but i did same with a light recently
zackyd
Aoktar, could you please get together an example using a light? I am unable to get anything close with putting the texture into the light.
it's here
proj.zip
(542.42 KiB) Downloaded 597 times
zackyd
wow... thank you Aoktar. :)
nikolas
Hello, I've downloaded your zipped file. But: I can't rotate the projected pattern. How can I rotate for animated light for example?
Thank you.
KHENSU
Hello aoktar,
Thank you for the file. I sometimes get a distorted projected image which bends larger out to the sides from the center (kind of like a pin distortion) when I load a new image in place of your colored grid which projects undistorted. Is there some way to keep the projected image from being distorted? I've tried selecting "Cylinder', Sphere" etc but get the same result.
Thank you in advance
Win 7 64 | GTX780 6GB | GTX 460 2GB | i7 3770 | 16GB
