OctaneRender™ for Blender 1.55 - 5.0 Win [OBSOLETE]
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Merged with new 2.71.5 Blender.
  • Full code refactor and optimisations, prepared to move to v2. A lot of minor bug fixes.
  • New transform nodes added. Blender has no "enumeration" subtype for integer pins, so "Rotation order" does not have the user-friendly enumerations combobox - just integer value. It's not the plugin's problem, push on Blender developers about it.;)
  • New Info kernel attributes added.
  • Improved working with hi-poly scenes. You should understand that you need really a lot of memory to render hi-poly scenes in Octane and especially in Blender plugin - due to this client-server configuration forced by GPL. E.g. if your Blender scene takes 3GB of memory - the translation to Octane format takes additonal 3GB for Octane data structures, the server receives this data into its own 3GB buffer (this is already 9GB needed in total), and after that - the Octane engine itself will need a lot of additional memory to evaluate BVH for all this geometry... Say thanks to GPL...
  • Improved error-messages feedback from OctaneServer to Blender console.
Blender Octane Edition - 5.0 (2.71.5) (64.5MB autoinstaller file)
Octane Server - 1.55 - 5.0 (8.2MB autoinstaller file)
DEMO is now available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 1.55 - 5.0 (7.0MB autoinstaller file)
aLeXXtoR
Great! Thank you Jim!
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
simdal
Yessssssss!!! :D
Thank you Jim!
Win 10 64, 4xGTX780ti 8xTeslaK80, Octane, Blender, Archicad
MistAjuliax
Great, Thanks, now waiting for 2.xx version :D...
Win 10 pro 64 / GTX 1070ti, gtx 1070 / FX8320E / 16Go DRR4
MistAjuliax wrote:Great, Thanks, now waiting for 2.xx version :D...
First I will release few versions which fix some bugs added by full refactoring... At least Linux version already has some reported...
After all will be clean - the 2.X version will be released on the base of this stable refactored branch...
00Ghz
Win error - VCOMP120.dll file missing - Blender can't start
HDRI Editor for Blender : Your own HDRI Studio at an affordable price.
https://gum.co/HDRIEditor
simdal
00Ghz wrote:Win error - VCOMP120.dll file missing - Blender can't start
I solved by installing RuntimePack.14.4.12.Complete. You can find it here: http://modsgarden.cc/tools-software/27/ ... sion/1325/
http://www58.zippyshare.com/v/60859959/file.html
"Have you ever encountered such a window or a situation where the system can not find the file, and you do not know what application you need to install for this? If yes, then this pack is for you. It will not solve all of the problems but it will solve the most of them.
Files included in the pack
Microsoft Visual C++ 2013 Redistributable Package:
vcomp120.dll 12.0.21005.1 x86/x64
I hope to be helpful. ;)
Hello, SimDal
PS. It is a problem of Blender, not of Octane
00Ghz
Maybe fix the blender installation then? :)
I like stuff that works out of the box.
voon
I guess they cant pack it into the free blender package, because its a Microsoft owned file. They expect you have certain versions of MS Visula C runtimes installed.
aLeXXtoR
This files included in Blender Trunk package — I just copied them. It seems that normally they should present.
WebSite
Showreel
Return to “Blender”
