Hi Paul,
I have been using the 'save render target to view' to view setting. I am wondering if you could put something like 'update render target' or something that would allow us to keep all otherwise relevant settings when tweaking a view's camera position in Revit, AFTER having saved the render target to view. The only way it seems to be able to update the render target camera position 'permanently' is to revert load from default - which messes up the camera position - and then 'delete render target from view', then 'save render target to view' again.
Best,
Seeker
Render targets and camera positions.
- Seekerfinder
I just checked the latest version - and if you move the camera of a saved view, it automatically updates the Octane camera to that camera position - so it is working as you want it. It is possible that you have Viewport Navigation on for the view you are enabling (in this case the Revit camera will not override the saved Octane camera position).
- Seekerfinder
Mmmm. You are right! But I had this issue a number of times on 'elevation' (DOF=179 views)... ??face_off wrote:I just checked the latest version - and if you move the camera of a saved view, it automatically updates the Octane camera to that camera position
I will see if I can catch it again.
Seeker
