Instances use more memory
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
coilbook
Hi Why when I instance an object octane viewport shows more memory used. I thought instances dont use extra memory thanks
MaTtY631990
What release are you using.
coilbook
MaTtY631990 wrote:What release are you using.
hi I am using 2.5 Thanks
MaTtY631990
Try 2.06 plugin. If not it might be fixed in 2.07.
thanks.
Karba
coilbook wrote:Hi Why when I instance an object octane viewport shows more memory used. I thought instances dont use extra memory thanks
How many instances do you have?
coilbook
like more than 10
just tried a new scene with 2.06 and when I copy a sphere 20 times memory usage goes to 0.19mb
when i instance same sphere 20 times I get 0.14 mb almost same as copy.
I used Plain sphere (39,000 polys) no textures and shift drag to copy and instance , single sphere used 0.04Mb
Karba
Do you use movable proxy option?
coilbook
Thanks Karba it works!
I thought movable proxy is only for real time update in octane viewport only.
coilbook
so should i select all my objects in the scene before the rendering starts and check Movable Proxy to reduce memory during actual rendering or it is only for octane preview and instances during render will automatically be recognized and wont use any extra memory ?
nildoe
Movable Proxy is for instances and moving/deformable objects, as Karba once explained.
The rest should be set at their default state, because Movable proxy also tens to slow down the render a bit.
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
Return to “Bug Reports”
