Feature requests
Seekerfinder
Hi Paul,
I'd like to request a few minor(?) features which would be useful in my (and others?) workflow:
1. Esc to close proxy window;
2. Auto random-rotate /-scale (by selectable range) the elements propagated with 'proxy replicate' function (I vaguely recall this being requested before?);
3. Ability to apply 'favourites' material to a new maxed material node.
[EDIT] 4. The ability to save preferences please. Every time I start a new project there are a few setting I change as a matter of routine - particularly FOV and resolution. Aperture is another I often change. It would be great if we could create preferences for default node settings.
Also, did you change something in the way VP navigation works since it's first implementation? I have been really struggling with navigation control lately - over-sensitive zoom / pan (around a selected Revit element). At first I thought it was because of a large model I was working on but I am experiencing the same thing with much smaller models. It just seems as though something kind of broke along the way because my recollection was that is was much better at 'some' point... Or was that in another life?
Best,
Seeker
Done in the next release.
Doable in a future version (added to the medium-term list).
Unsure what a 'maxed material' is - sorry.
Rightclick Settings tab tree "Save as Default".
Hasn't changed. If you select a Revit item - that item is used as the centre of rotation and to scale the zoom. So I think you might have something selected too close or far from the camera which is causing your problem.
Seekerfinder
Thanks Paul!
Great.
MIXED or MIX material node I meant to say.
Ah yes, the manual is quite clear on this - thanks Paul.
I am familiar with how it works since beta days and use it all the time and I make sure only one element is selected - preferably as small as possible. It's just that my 'impression' is that it used to be more user friendly somehow. But if you haven't changed anything, obviously that is not the case. I wonder if we could improve it somehow? Is it possible to add a 'sensitivity' / speed slider to the control? Alternatively, could you port the subsampling-setting from Octane as a test?
Seeker
Applying a favorite into a material within a material mix would be complex to implement (since the plugin would not know if you want to replace the whole material mix, or just one input. I'd rather leave this out for the moment.
I will implement subsampling in the next release.
Seekerfinder
Just assign it to a node, like in Standalone? Didn't think this would be rocket science.
Thanks Paul.
Seeker
That reminds me of the Far Side cartoon where the rocket scientist are building a rocket that is falling apart. The "import" function is all geared around replacing an entire material node with another. It has to replace the whole tree control for the material, and plug the imported material into all the geometry pins that used the original material. So importing a material into part of an existing material would require significant re-engineering of the plugin, and the effort to do so would not match the benefit to users.
Seekerfinder
I thought that's why they pay you the big bucks, Paul... I did not mean to trivialise the work required. But users needs are evolving and, since we cannot yet import a custom materials library (created in standalone), I find the need to create a useful materials library inside of Revit (saving to favs) more and more. The mix materials node is very useful in this regard.
I think we'll end up at the ability to access custom material libraries, in which case such a need would be all but redundant. Importing OCS files as proxies will solve this as well since it will be a mechanism for materials import - I think you advised we contact Otoy to address some core functionality for this to work - I'll dig up that post and ask Otoy for a bit of love. It remains my no.1 feature request (in case you did not know... just kidding).
Best,
Seeker
Seeker, the next version of the Revit plugin is pretty much done, and has the "Import ORBX Material" function (and subsampling). I'm waiting on it's release until I get a journal showing the Octane Material issue so that I can include a fix for that in the release.
Once the "Import ORBX Material" function has been tested and proven to be robust, I will look at "Import ORBX Proxy".
Seekerfinder
face_off wrote:Seeker, the next version of the Revit plugin is pretty much done, and has the "Import ORBX Material" function (and subsampling). I'm waiting on it's release until I get a journal showing the Octane Material issue so that I can include a fix for that in the release.
Return to “Autodesk Revit”
