Team Render Setup
creativebloke
I searched for this in the forum but couldn't find an answer. I need to run Octane via Team Render for a job I'm working on. All seems fine until The team Render Client says there is an 'Empty Account/Password!!!' which causes an initialization error.
I copied my Octane plugin from MY C4D folder on the same machine, and I have Full Octane Licenses with plugins running on Client and Server.
The manual isn't much help with this so any help would be welcome.
twitter = creativebloke
how do you start a client? If you start as client it checks different folder for a "oct.dat" file. this file holds your account
creativebloke
On my main Octane machine which I want to use as the team render client, I copied the c4doctane plugin folder from the C4D plugin folder to the Team Render Client plugin folder. I then use another weaker PC, which I want to work on to run CINEMA 4D with team render using the main Octane machine as 'The Client'
ok, you should put "oct.dat" to client preferences folder.
creativebloke
Do you mean the 'octane.dat' in the main octane folder?
creativebloke wrote:Do you mean the 'octane.dat' in the main octane folder?
NO. i mean "oct.dat". It's in prefs folder.
buerobewegt
I have installed C4D R16 TeamrenderClient. Where do i have to copy the oct.dat. I can't find the Client prefs folder. I always get the same message:
Octane Render for Cinema 4D 2.05.0
Octane Render SDK version: 2.05.2
Emtpy Account/Password!!!
Initialization error!!!!
buerobewegt
I just updated to version 2.06.1 and now it seems to work :D
