OctaneRender for Carrara 2.06.0048 [Test]
Carrara (Integrated Plugin developed by Sighman)
Sighman
WARNING: This version has had limited testing. Use at you own risk.
This update contains a single fix for an issue where animations do not always update in the ORVP. This should fix an issue with a door reported by SciFiFunk and a Physics simulation reported by orion_uk and others.
Note that this 'fix' removes an optimization that tested to see if an object was animated before processing it. Since this optimization has been removed it is up to you to unset the Animated flag on static instances. Unsetting this flag MAY speed up the processing time between frames.
Unset Animated on Static instances.
Also note that the installer no longer prompts you for the Install directory (as it was not working anyway). It is up to you to check that the install path is correct for your Carrara installation. (I hope to completely replace the InstallShield installer with WiX at some point in the near future.)
Download Links:
OctaneRender for Carrara (64-bit) 2.06.0048
OctaneRender for Carrara (32-bit) 2.06.0048
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
SciFiFunk
Brilliant!
Thank you so much for a quick turnaround on this essential fix. I'll test it ASAP after lunch. Currently munching away right now.
orion_uk
Thanks Sighman ;)
Having a family day today so will look in to this and respond to other posts later tonight.
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
SciFiFunk
Sighman,
I am running that same door scene now. I am trusting that the fix works, so rendering out at "full" quality. A paltry 240 [EDIT 300] samples is enough for this test animation. It won't be long until it gets to the door opening then.
One thing I did notice is that the initial start up time (for the first frame) is longer. I am yet to test "unanimating" by unticking that box to see what a difference this makes on static items.
I guess I'll need a few tests before I am totally sure. It wasn't always failing on the previous version [0047]. The door opens a couple of times in the animation, so at least 2 tests then.
This little effort is to get me going, after that a larger scene (a space shuttle) will be animated. (Have to complete the modelling first).
SciFiFunk
Worked on the first test. Thanks. :)
SciFiFunk
2nd test.
Problem. I kept Carrara open after that first multiframe render. I opened a new scene, which is the same scene but with different animation. I set up my render settings again, started the animation.
After the first frame (which was fine), the second and subsequent frames didn't render. In Carrara I can see the animation frame advancing. It was writing the frame out with the new frame number, but the contents was always the first frame.
I came out of Carrara completely, came in again and all was fine. I conclude the original problem still persists, at least from a user point of view. I can't be sure if it's going to animate correctly.
NB This animation was just a camera pan moving downwards.
Tugpsx
Thanks for the update
Tugpsx
Something interesting, since this last update, whenever I click the "Open Settings window" option an image file open dialog box pops up; once I close the dialog box the setting window pops up.
Anyone else having this issue. It just started with this release.
Sighman
Orion has reported this a couple of times, I have not been able to reproduce it. It is good that others are now repeating it so I can mark it as a confirmed issue.
orion_uk
Ahhh, you never knew about my secret time traveling abilities did you Sighman ;)
:D
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
Return to “Carrara”
