Hi, how can I change ip on the Daemon Scan Subnet on master when doing Network rendering, now it's 192.168.1.0/24, I need it to be 0/30
thank you
Daemon Scan Subnet change
- [email protected]
Windows 10 64bit, Intel i5, 32gb Ram, 2x nvidia 1080ti, Driver: 390.77
- stratified
You need to disable network rendering first. Then you can change the daemon scan subnet. The subnet 0/30 looks a bit fishy though.
cheers,
Thomas
cheers,
Thomas
- [email protected]
if I disable it, I get the dropdown menu for IP, but there I can only select the IP (0/24) I mentioned, and no other option to change it ---> http://prntscr.com/4h95i6
on Octane standalone I get the option to enter IP manually ---> http://prntscr.com/4h95pa
- [email protected]
sooo... how to change it?
- [email protected]
bump... can I get some help on this?
3 computers here have octane, don't have an option to change scan subnet, on Octane standalone it works... but on max version I don't have the ability to put it above 192.168.1.0/24 (look screenshoots above)
- stratified
You're should update your version of the Standalone. In the newest version you don't have to manually configure the subnet range anymore.[email protected] wrote:bump... can I get some help on this?
It should work as is if you have the newest versions. Can you find daemons on your network as described in the manual: http://render.otoy.com/manuals/Standalo ... ge_id=1269.
regards,
Thomas
- [email protected]
Standalone is not an issue, on standalone I had the option (in the newer version 2.06 I don't have anymore) to enter value I wanted.
Issue is 3ds max plugin, I can't make Ip scan range higher... max scan range is 192.168.1.0/24... I need it to be 192.168.1.0/30.
is this possible to change in 3ds max plugin?
- stratified
In a subnet mask like 192.168.0.0/24 doesn't mean that you can have only 24 machines. It means that 24 bits are used for the network address and 8 bits for the host address. This means that your subnet supports 2^8 - 2 = 256 -2 = 254 hosts (the -2 comes from 1 for the network address and 1 for the broadcast address). In this example the valid range of ip addresses is: 192.168.0.1 - 192.168.0.254.
We don't arbitrarily choose this subnet in Octane, we take it from the network configuration on the machine. You should see the same subnet when you issue
cheers,
Thomas
ipconfig in a Windows command prompt.cheers,
Thomas
- p3taoctane
This might not be technically possible.... but it would be great if you had the option to enter the in the IP addresses of the machines you wanted to be slaves.
The automatic fill in is fine ... but having the ability to type in several IP addresses of the machines you know you have and want to use would be perfect.
Is that an easy thing to do... and is there a good reason not to have that option?
Peter
Peter
