failed to initialise CUDA driver API
marchermitte
Hello! Everything worked fine, I didn't change anything and all a sudden I'm getting this error (log file):
Started logging on 24.08.14 10:54:26
OctaneRender version 2.05.2 (2050002)
CUDA error 999 on device 4294967295: An unknown internal error occurred.
-> failed to initialise CUDA driver API
I updated the drivers but still, no change.
what's wrong?
Marc Hermitte
Intel I7 4.5 Ghz, 24 gig ram, 2x Nvidia GTX 480, win 764bits
marchermitte
PS: I checked in Octane standalone and the cuda device is recognized but not by the Modo plugin. I re-installed the newest drivers twice (clean install) , restarted the computer, still the same.
Marc Hermitte
marchermitte
Ok, I did a system restor to 15 days ago, when everything worked well and at first It seems to work but when I rty to open the previiew window I get this log file error:
Started logging on 24.08.14 17:50:55
OctaneRender version 2.02 (2020000)
Tried to access attribute via invalid ID A_VALUE (161)
Tried to access attribute via invalid ID A_MAT_PREVIEW_DPI (59)
Trying to set array in attribute of wrong type
Tried to access attribute via invalid ID A_NUM_CONTROLPOINTS (75)
Tried to access pin via an invalid ID P_UP (169)
Tried to access null node pin
Node type 51 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid ID P_GENERAL_VISIBILITY (50)
Tried to access null item
Tried to access attribute via invalid ID A_VERSION (162)
We can't evaluate items of a different version (version 0)!
Tried to access pin via an invalid ID P_TOLERANCE (164)
Node type 33 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid ID P_DIMENSIONS (24)
Tried to access pin via an invalid ID P_STEREO_MODE (150)
Tried to access pin via an invalid index 1
Can't connect node 'AUGUILLES' (NT_MAT_GLOSSY, 000000002A290C50) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid index 2
Can't connect node 'METAL_BRUSHED' (NT_MAT_GLOSSY, 000000002A291650) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid ID P_ENABLED (35)
Node type 54 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid ID P_PREVIEW_OBJECT_TYPE (119)
Tried to access pin via an invalid ID P_TEXTURE2 (161)
Tried to access pin via an invalid index 3
Can't connect node 'RADIUM' (NT_MAT_DIFFUSE, 000000002A3C7420) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid index 4
Can't connect node 'WHITE_CADRAN' (NT_MAT_GLOSSY, 000000002A3C7A20) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Node type 34 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access attribute via invalid ID A_FILENAME (31)
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Can't write bool to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Node type 27 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid ID P_SCATTERING (138)
Tried to access pin via an invalid ID P_TURBIDITY (168)
Tried to access pin via an invalid ID P_ROUGHNESS (131)
Tried to access pin via an invalid ID P_CAMERA (15)
Node type 36 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid index 5
Can't connect node 'BOITIER' (NT_MAT_GLOSSY, 000000002A3C8420) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid index 6
Can't connect node 'LETTERS_CADRAN' (NT_MAT_GLOSSY, 000000002A3CE9E0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid index 7
Can't connect node 'METAL_BRUSHED_2' (NT_MAT_GLOSSY, 000000002A3CF3E0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid index 8
Can't connect node 'REMONTOIR' (NT_MAT_GLOSSY, 000000002A3D03E0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid index 9
Can't connect node 'INOX_NORM' (NT_MAT_GLOSSY, 000000002A382400) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid index 10
Can't connect node 'lETTERS_CADRAN_Black2' (NT_MAT_GLOSSY, 000000002A383100) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid index 11
Can't connect node 'FERMOIRE' (NT_MAT_GLOSSY, 000000002A3875A0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid index 12
Can't connect node 'lETTERS_CADRAN_Black' (NT_MAT_GLOSSY, 000000002A3885A0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid index 13
Can't connect node 'TOUR_CADRAN' (NT_MAT_GLOSSY, 000000002A388FA0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid index 14
Can't connect node 'CADRAN' (NT_MAT_GLOSSY, 000000002A3DCD50) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access attribute via invalid ID A_POLY_MATERIAL_INDICES (102)
Tried to access pin via an invalid index 0
Can't connect node 'Non-Live Items mesh' (NT_GEO_MESH, 000000002A29BBF0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid ID P_MIN (96)
Can't connect node 'Geometry Group' (NT_GEO_GROUP, 000000002A254BB0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Node type 77 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000001037A040)
Tried to access pin via an invalid ID P_RIGHT_FILTER (127)
CUDA error 500 on device 0: Named symbol was not found.
-> failed to find CUDA symbol (imager settings)
device 0: failed to initialize resources
I'm supposed to demo Octane for Modo to my clients on thuesday and I'm really stuck with this... any idea?
Marc Hermitte
Hi. Either there is some geometry in the scene tripping up the plugin and/or Octane, or the installer did not complete correctly (because Modo was running with the installer was run).
1) Does the problem occur on a simple scene with just a cube in it?
2) Try uninstalling the plugin via the Control Panel and then reinstalling.
marchermitte
Hello paul!
Took me the day but I got It solved . I uninstalled everything and re-installed from scratch and everything works now. Plus I lowered the priority for the vido board, I've read in the FAQ that the card might get too hot and freak out Octane/Modo.
Yes, the problem arised even with a simple geometry.
The strange thing is that the live plugin stopped working without my changing anything to the computer and at first, It didn't detect the board at all. After I resored the system to a previous state, the board was seen by the Octane live plugin but I was getting this code 500 error. In all cases Modo standalone kept working fine.
Anyway, evrything fixed now! thank you .
Marc
Marc Hermitte
Good to hear you are up and running. The symptoms you had are typical of what you would get if you installed the new version of the plugin whilst Modo was still running. I plan to add a check in the install to ensure Modo has been shut down prior to installation.
sjogren
Hello, I have this problem now?
I think I have tried everything, tried to uninstall, restart computer and install, uninstall and re-install Nvidia drivers, no luck!
When I start Modo I get:
An Octane error has occurred. Check the Octane Log for details
I get this in the Octane LOG:
Started logging on 29.09.14 21:44:18
OctaneRender version 2.10 (2100010)
Need some help...
/Niklas
Windows 10 (64-bit) | GeForce GTX 1070 & 970 (416.34) | i7 6850K | 32 GB System Memory
Modo 12.1v2 | Plugin Version: latest beta 4
Hi Niklas - is Octane Standalone (2.10 and 2.06) working OK for you? If you reinstall the previous version of the Modo plugin that you were using, is the problem resolved?
sjogren
Hi there ...
I think it has been there in previous versions, installed the new version yesterday, but I have seen "An Octane error has occurred. Check the Octane Log for details" for a long time but had not the time to investigate more?
If I start the rendering Window the window is black, but I guess thats not strange with the error!
Feels almost like Octane for Modo does not see my video card (a feeling/guess)!
/ Niklas
Hi Niklas - I cannot help you unless you answer my question from above...
Return to “Foundry Modo”
