object sequence animation motion blur bug report!
kevinshane
Hi dear admin
When I trying to import an object sequence animation(such as realflow bin files,or prt files meshed by Frost),Octane doesn't produce any motion blur(vertex motion blur check ON),also the realtime viewport became very slow,even impossible to rotate viewport or change material settings, until I shut the motion blur off,and then everything became smooth!
Please fix that and make it work! Thanks!!
MSI GT70 laptop i7-3610QM+32G+GTX680M 4G
Octane Arch/Interior Viz Tutorials
http://www.kshane.com
FooZe
Hi, Is this in a particular plugin?
Chris
kevinshane
FooZe wrote:Hi, Is this in a particular plugin?
Chris
Hi FooZe,
yes I am using realflow for 3ds max to import the .bin sequence animation files! But not exactly plugin needed!
realflow can also create a single alembic file,that can store the whole fluid simulation into a single abc file,but still,octane can't produce any object motion blur(I have to say this is not only deform motion blur,but also the polygon counts changing every frame,like a fluid,u know :lol: )
There are many options to bring sequence animation file into 3d app like 3ds max, I am currently using script to import .obj sequence files,so they are only obj sequence,the script reads object info every frame,but again,octane can't do the motion blur work!(u can find the script in scriptshot.com for free)
Also Octane render can't produce motion blur on rayfire obj! So does the realflow .bin files, and Naiad .emp files,or even .prt files meshed by using a plugin named Frost!I've try every possible option to make the sequence animation to work with octane but every option is a dead end!
So sorry for my english,hope I make this clear :oops: Please make the motion blur work with sequence animation!
FooZe
I think I understand, I will move this to the 3ds max plugin forum.
Karba
kevinshane wrote:Hi dear admin
That is because every object in sequence has different topology. I am working on it to fix.
coilbook
Is it possible to do any motion blur with realflow yet?
Karba
coilbook wrote:Is it possible to do any motion blur with realflow yet?
I hope It will be possible in next release.
I am fixing it at the moment.
coilbook
Thanks!
mikinik
hi, Karba. motion blur with realflow in 2.16a version does not work. when it's done? :(
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
coilbook
mikinik wrote:hi, Karba. motion blur with realflow in 2.16a version does not work. when it's done? :(
and realflow bin mesh update does not work still
Return to “User Requests”
