Lua script for rendering an animation with several cams
Forum for OctaneRender Lua scripting examples, discussion and support.
DayDreamer
Hello there, I've been reading forum and scripts, and they are overwhelming with helpful information:)
I have an alembic animation with several cameras capturing the same shot. There is a script for animated sequence, and one for several RenderTargets, which is nice, and yet I can't simply combine those.
In a nutshell, I'd love to:
  • Load a frame, render it with camera1,
  • change to a different rendertarget for a ZDepth pass,
  • render the same frame with camera2,
  • continue selecting cameras until they run out,
  • switch to frame 2...
  • Loop until endframe is reached
It would be wonderful, since a single frame takes about 5 seconds to load with selective update enabled and if you have to load the same frame, say 4 times just to render it from a different position, and there are 500 frames... it's easy to see the waste of time here.
I will appreciate any help from you guys, since the time is short. Also it would be beneficial for people willing to have a multipass function, which is not yet implemented.
CPU: 5930K i7, GPU: 2x iChill Nvidia 780Ti, 980, RAM:32GB, Win 7, SSD.
Return to “Lua Scripting”
