The rendering of open and raise the work RenderQ second or third Scenes from the light wave is always terminated with an error. I thought that everything in only one system has seen similar symptoms in other systems.
Use the Build 2723 ver11.6 jungyigo LightWave version 2.02 version is in use Octane is.
System 1 is win7 z97 i7-4790 32G 780ti 4way
System 2 is win7 x79 i7-3930 32G 780
It is so busy.
Are you still not fully compatible with RenderQ?
This Scene Is it heavy? 960 million polygons?
RenderQ Error
Currently RenderQ only supports two scenes. It has a bug with the external render engines.
If you need to batch render more that two scenes you can configure LWSN in your workstation to render multiple scenes using the Lightwave network rendering tool.
http://render.otoy.com/manuals/Lightwave3D/?page_id=408
