Viewer window freezing when using Octane render in C4d
davidtorpey
Hi
I'm not sure if anyone has the same problem as I do with my viewer windows in Cinema 4d when using Octane 2.02.
All the viewer windows work fine, when I am navigating and moving items around on screen. But when I activate the Octane Render window I start having problems.
So the window which I select doesn't update but the other windows do. For example if I move an object in the camera view - it does't move in that window but does in the other windows open. The only way to have it work is to only have 1 view open at a time.
If I pause the live update in the Octane Live Viewer Window all the other viewer windows work fine.
I am running on Mac Mavericks with a GeForce GTX 690 and 64Gb Ram. So I have the power I need.
Any thoughts
Cheers
David
enigmasi
but power you need is vram, and if you have just one gpu, then it may not enough for both scene and system
of vram is enough but you didn't enable priority for card
there's no problem on last versions. can you capture some video to show it? but pls first try to do a clean install for 2.03 or 2.02
