hair...still can not render?
Autodesk Softimage XSI (Developed by Face)
e880291
I use plugin i.01---------------Windows 1.01 beta Plugin for Softimage® x64
and Octane render standalone 2.03
I still can not render the hair in softimage this verson
but i saw the new verson RELEASE NOTES:
Hair rendering
An optimized hair render primitive is now available to allow rendering of hair or fur while reducing memory usage by 20 times compared to previous processes. OctaneRender™ 2.0 will also simulate the distribution and fluidity of movement of those primitives. Hair rendering is mainly a render feature and the geometry needs to be provided via the scene. The Alembic importer supports reading spline/polyline data and converting it into hair primitives, by either using the hair thickness stored in the Alembic file (if available at all) or using the default thickness specified in the import preferences.
But how to do this with softimage??
even I use Alembic file export ,I just use the polyline but not the "hair" right?
is there any tutors step by step tell us what it says?
face
The release notes are for Octane 2.0.
The new 1.02RC10 plugin is still for Octane 1.x.
I will first make a stable release with all features impemented before i switch to 2.x.
The only way i see is to use Alembic, but i don´t know how to setup Alembic to export hair or ICE-Strands.
I see that this will not help you, but it shows the way i want to go.
When i switch now the plugin to 2.0 and add the features which are missing, you have to buy a new 2.x update.
I think this isn´t fair for 1.x users which have also paid for all missing features.
I wish i would have more time to develope, but i´m only a one man show with another job.
So i can only develope in my spare time and this is realy slow.
Sorry for this,
face
http://vimeo.com/user2509578
e880291
The only way i see is to use Alembic, but i don´t know how to setup Alembic to export hair or ICE-Strands.-----------------------yes I also don't know how to do this....
thanks for your help
the softimage2015 is the end verson.... do you still to develope the 2.X plugin for softimage2015?
we hope you can do this ,no matter how it is slowly )))))
face
e880291 wrote:The only way i see is to use Alembic, but i don´t know how to setup Alembic to export hair or ICE-Strands.-----------------------yes I also don't know how to do this....
Yes, i will develope the 2.x also for 2015.
face
e880291
we are deeply grateful!!! :D
e880291
if we can not render hair in xsi plug in
how about we use the Alembic??? and render fur in octane stand alone verson?
http://exocortex.com/products/crate/description
did you try this way before?
by the way...
my company maybe plan to buy redshift because we can use it render fur , but I really don't like this choice ( I love octane render and concept.... ) we can't wait the new version , if it still need very long time to develop...
face
e880291 wrote:if we can not render hair in xsi plug in
by the way...
The hair would only render in Octane standalone 2.x.
If you have it, you must also pay for a new 2.x Softimage plugin which isn´t available because i still use the 1.55 SDK.
I wouldn´t change it since all is implemented, but maybe i can switch between different SDK packages and has one code for both plugins.
Must test it,
face
e880291
I'm very looking forward to rendering Fur in softimage
because my studio must use it to do our creative movie..........
for now, my partners use a plugin to transfer ice to mesh (fur using ICE)
and also try to use fur to Instance
but...all the same problem...the texture of fur on the skin will be miss.... (like a Stripe of tiger or Zebra......)
face
Have you tried the free Soft2Octane exporter? It´s more an external solution, but it will work with ICE.
http://render.otoy.com/forum/viewtopic.php?f=29&t=33321
For stills it can be an option.
http://www.vimeo.com/26567419
Do´t know with which Softimage/Octane version it runs, haven´t test it ;)
face
e880291
this is very cool
and I still have last two question(still the hair question)
even I use this way(use ICE make fur or hair)
how can I control the texture of all the skin(like...tiger or.Zebra),and the color map of root to tip? :D :D :D
thank you,Face
Return to “Autodesk Softimage XSI”
