Hi
Does the plugin version support the 750 and 750ti cards. Can't seem to get it working.
750ti
- MaTtY631990
Hi Karba
1.53a and latest driver version 337.88. 1.55 won't install properly, I use 3dsmax 2011. I have not upgraded to octane 2.0 yet, and it is not a necessity for me at the moment. The standalone version 1.54 and above works fine with card.
What is the problem with 1.55?MaTtY631990 wrote:Hi Karba
- MaTtY631990
Error loading dlls
Octane3dsmax.dlr > failed to initialize
error code 126 - the specified module could not be found
- MaTtY631990
Not sure the 1.55 version would work as well with the card because someone else has issue with no memory being loaded for the card.
- MaTtY631990
All files are there but when I launch 3dsmax I get error.
- MaTtY631990
3dsmax 2011, will run the installer again and double check.
