Light emitters - colours
Moderator: BK
Hubby72
Hello,
i am new to octane and its DAZ Plugin. After playing around some days i am quite comfortable with it.
But some thing i had in DAZ i am not sure how to set it up in octane.
I know how to set a simple light emitter. I know that with diffuse , power and temperature i can adjust the colour. But to be true. I am not satisfied here.
If i lower temperature level it goes to yellow-orange-red ..
if i raise temperature level it gets a bit blueish.
Changing the power to that works fine. bringing the power to high end up in bright white light.
but my question is How for example do i create a simple green light ? I can change diffuse to green.
And play around with temperatur and power and i never gets any greenish light. Only from red-orange-yellow up to white and blueish (not blue).
Could anyone "enlight" me ? ;)
Win 10 x64 | Zotac Geforce GTX780 6GB, Gigabyte GeForce GTX 960 | Intel Core i7 3770 | 32GB Corsair DDR3-1600 | PNY 480 GB SSD |
My Blog : http://www.subwaytotatooine.de/
My DA : http://hubby72.deviantart.com/
Elele
Did you try to use texture emitter instead of black body emitter?
For the texture emitter you can set the color in the "efficiency or texture" slot
PS:...enlight ...giggle :D
Hubby72
Hmm if it is so easy i did misunderstand the documentation for that it seems :)
I will later at home. thanks
Edit Feedback. It works as described. Thanks for the answer.
gaazsi
interesting thread... i am also new to octane and playing around for some days now, solved the biggest "problems" meanwhile
but one question still remains :D
in render settings -> imager sets -> response... is there a true color "neutral" option?
atm i use the preset agfa color hdc100, which has a little yellowish touch but easy to adjust with white balance. its not that important but would make a beginners life easier maybe :) or are there more of those presets available for download anywhere?
Return to “DAZ Studio”
