There is a bug in octane regarding the visibility track.
On a single object the visibility track works perfect and as expected.
But when you put two objects with similar/overlapping geometry on top of each other octane goes haywire.
Simbple testscene with two teapots. One is visible from frame 0 to 10, the other from 10 and outwards.
http://1drv.ms/1p76bhO
Visibility Bug
Any render doesn't like overlapping geometry. If you use the same geometry, why don't you just animate material on it?nagboy wrote:Hi,
- Andreas.visjon
- Contact:
you should not work with the visibility track, doesn't matter which render.
You can easily render 2 pictures and blend them in post production, its much faster also. Why to render all the blending frames?
_________________
Win7 Prof | MSI X99S SLI Krait Edition | Geforce GTX980 4GB | 5820K | 16GB
This is the way rayfire handles the splitting of objects in the scene. I cannot change that as much as I dislike the visibility track. That said its a pretty smart way of doing it, motion blur is calculated correctly because the verticies are technically in the scene. Octane should interpret values of 0 and 1 in the visibility track differently, as a binary switch if the object is in the scene or no - but still keep the verticies there for motion blur.
