key framing motion blur question
zackyd
this is a bit of an odd request but what I am trying to achieve is animating the lengthening of the shutter speed of motionblur. This is a challenge because the object is keyframed with motion but need the same motion for every frame so the motion blur is the only thing that is animating.
currently to achieve this I am only able to use the live viewer and saving out of the octane dialog, and then adjusting the shutter speed, repeat..
any ideas or thoughts on how to achieve this in a more automated fashion (though the picture viewer)
my initial thoughts are that the only way to do this is manually through the live viewer.
thanks for any input!
(playing around with motion blur w/ 2.2 is the most fun I have had in c4d in a long while. thanks!)
4x GTX 780 6gb // 32gb ram // 1600w
theoretically it's possible and easy. but you should have more key frames if shutter is being bigger than previous frame. currently it clears the old keys when advanced to next frame. so it can works if shutter value is decreasing. needs some changes for opposite
