lightwave Octane Render Network Preferences are unable to find the GPU. Locate and mark the Slaves Node Standardone Lightwave Plugin, which I can not locate the GPU.
Am I not setting?
I like 3d Max Standalone among users on the GPU to properly recognize the network but could not find the user half the suits Plugin
192.168.0.0/24 Subnet symptoms listed for use and realistic.
Standalone licenses of two and holds licenses in two of the lightwave plugin.
Under normal installation, use, or those that need help.
network gpu setting
If you have problems with network rendering, try first to configure the Standalone application to see if the problem is in the Lightwave side.
If network rendering works with Standalone, but not with Lightwave, try to disable the Windows Firewall before launch the Layout. There are some outbound rules added by the Lightwave licensing to the windows firewall that blocks the Octane network.
If disable the firewall fix the problem, but you want the firewall working in your system, you need to delete all the Layout outbound rules enabled in the firewall.
Thank you for answer.
Your setting tip I can give to the public?
I did not know the layout of network security and firewall, but the problem is where it should be possible to correctly do not know how to set it.
My system is win7 ultimate k version in use.
Check when setting should do, please let us know which part.
Seek advice about this part here, but the lack of interest so will contact you.
Standalone version is normally recognized by the lightwave plugin not recognize. A firewall is turned off and there is no other antivirus programs. What's the problem?
Many users will encounter the same problem like me Anything Like the man I wish I could get a really good help ....
The problem could the that the standalone version and the LW plugin version that you are using don't match. The Octane API of the plugin need to be the same than the standalone version.
Try this:
- Install the last version of the Lightwave plugin (the daily build 2.2.0):
http://render.otoy.com/customerdownload ... _build.zip
- Install in the render node and in your workstation the 2.02 Standalone version:
http://render.otoy.com/customerdownload ... _win64.exe
Try again the network render. Be sure that you are using this versions of the plugin and standalone (you can see the plugin version in the "about" window)
Try this:
