OctaneRender® for Maya® 1.55 - 3.9 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 359€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Fixed Octane scene export bug.
DOWNLOAD
OctaneRender for Maya 1.55 - 3.9 (28.8MB autoinstaller file)
Yours,
The OctaneRender™ Team.
prodviz
Cheers, Jim.
Slimshader
I've run into a problem where the roughness setting of a specular shader globally changes the roughness for all the other specular materials. I'll pm a link to some scenes with the issue this evening JimStar.
Return to “Autodesk Maya”
