tonysculptor skin R20
tonysculptor
Hey all,
I just uploaded a new version of my skin shader for Octane 2.0. It now has displacement. I also optimized it a bit for speed and ease of use. If you build your models to real world scale, and plug a color texture into the "Color" slot with the gamma set to 2.2, it should just work.
I attached a small image of test renders of a model that is a work in progress. I started this model with a scan of myself I generated using my Kinect. I cleaned it up and sculpted details, as well as textured it in ZBrush. I have not tweaked any of the specular maps, but I am pretty happy with the result so far. On to the eyes next.
here's a link to the full size render:
http://www.darkcel.com/images/LightTestRenders.jpg
Tony Reynolds
i7 6 Core Processor | 680 GTX x 3, 4 GB VRAM | 128 GB Ram
nildoe
Hi Tony..
that very much for your contribution! i love your work..may i ask is the updated one called "tonysculptor Skin2" ? it does not show any "r20" in livedb.
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
glimpse
thank You! =)
pid18000
thanks for sharing
Much appreciated !
Win10 64 | GTX Titan | I7 5820K | 32GB
tonysculptor
The latest version may have not yet shown up in the db. I uploaded it last night, so it should be there soon. It is not the one labeled tonysculptor skin 2- it will have "R20" in the name. I will try to edit the older names for clarity
Tony Reynolds
nildoe
I see..Great Tony thx so much! anxious to try it out!
Nildo
Tugpsx
Thanks for update
tonysculptor
Another test render. I worked out the spec and added proper eyes. Hair is soon to come.
I created an example scene using my shader that I put together for nildoe here:
http://darkcel.com/OctaneRenderer/Infin ... Scene.orbx
I used Lee Perry Smith's model (AKA Infinite, http://www.ir-ltd.net/), but I adjusted the scale for proper rendering.
Tony Reynolds
Stevenyang0430
Is it possible to do this under Poser plugin?
I can't find a place under the plugin to put diffuse/color map
Tugpsx
Wow, this is cool. Thanks now I can get a good look at your scene setup. This will be a very great contribution for those of use who have been struggling to achieve your realistic skin.
Off to play with new toys. :)
Thanks!
Return to “Works In Progress”
