OctaneRender® for Maya® 2.02 - 4.1 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
This is the quick-fix release.
  • Fixed camera bug.
DOWNLOAD
OctaneRender for Maya 2.02 - 4.1 (30.6MB autoinstaller file)
OctaneRender for Maya 2.02 - 4.1 Demo (28.9MB autoinstaller file)
Yours,
The OctaneRender™ Team.
TBFX
Thanks JimStar,
Camera seem good now.
T.
TBFX
Hi JimStar,
There is some strangeness going on with hair systems. I've attached a sample scene. The polygon sphere should render white but once a hair system is in the scene it renders black or strange or not at all depending on which hair system I have tried, if you delete the hair system the sphere renders correctly again. Also once I set off an IPR containing hair Maya's UI becomes very unresponsive, I am not using my display card to render. Changing focus between Maya windows is incredibly slow as is cancelling the IPR render. Sometimes the slowdown persists after the IPR session has been stopped as well.
I would like to say that the implementation of hair seems really nice from a conversion of Maya PaintFX hair perspective as you have been able to retain per strand data like colour variations etc. and it works on plain paintFX not just hair systems which is really important for me, but there are a number of things, at this stage anyway, which feel a little locked down with the user not able to control much in the hair shader itself like specular and opacity, scattering or transmittance etc. It would be good to find some way for users to essentially attach their own shaders to a hair system or group of strokes/brushes with an option to pull per strand data from the PainFX as desired. Also being able to set geometry type and visibility settings on hair systems like any other geometry would be ideal, for these settings I'd imagine them being set globally on each hair system. However for both shaders and geometry settings I'd like some way to define a group of plain PaintFX strokes as a single hair system as I mostly don't use Maya's hair systems but set up my own dynamics and paintFX hair.
Are there any plans to support Maya Fur? I know it's difficult as it is itself a plugin and probably fairly locked down but Renderman for Maya is able to export all the curve data from a Maya Fur description to a RIB file so it must be possible.
Also is the gradient shader coming? I thinkl it's in some of the other plugins now.
Ok back to testing and awaiting MB once you get that implemented.
Testing in Maya 2015.
T.
hairSysTest.zip
(367.43 KiB) Downloaded 218 times
TBFX
Yes, I planned to improve the hair system from the beginning. It is just the first version.;)
About giving you more control over material - here are still some questions... E.g., it is easy to give you the opportunity to connect your own Octane material to Hair node. But here we will get some ambiguity: if this material will be extremely complicated and will be made from lot of mixmaterials-textures-etc, it will be extremely difficult to decide for the plugin what for attributes of which of these nodes to set with fluctuating hair colour from Maya's hair-system...
It is easy if e.g. you will always connect some simple not-mixed diffuse-glossy-specular material - the plugin will just set the colour of diffuse or specular attributes of it... But as soon as it will be some material containing few mix-materials in it - we will get some ambiguity here...
What do you think? How it will be convenient for you to work with it?..
Wenneker
I'm not really sure how the hair is going to work and if this is possible but it would be really nice if it is possible to have a color difference between the root and the tip. Maybe something as simple as the option to multiply the hair color scale with the diffuse colour of octane shader.
Win 7 x64 | i7-4930 | 64gb | 4x gtx 780Ti 3gb
kevinshane
hi jim
I still get 39 per node! and I bought the whole 2.0 standalone before! could u please check it out?? I have maya 1.x plugin!but paypal still tells me that I have to pay 39 euros per node! :oops:
MSI GT70 laptop i7-3610QM+32G+GTX680M 4G
Octane Arch/Interior Viz Tutorials
http://www.kshane.com
prodviz
Hi Jim,
firstly, I'd like to say a huge thanks for the plugin. It's working pretty sweet.
Here are my observations so far:
1
There are a few smoothing errors when using HDR lighting:
2
Some issues with faceting and edge splitting with displacement (I'm using a 8bit file which has been converted to 32)
3
The hdr file works ok, but when I change to daylight the geometry is blown out:
4
The maya preview renders as expected (once Gamma 2.2 is set. If anyone knows how to lock this down, that would cool. This needs changing on every new maya scene), but once saved as an Octane scene and opened in standalone, the shot is blown out.
The hair is awesome.
To cut down on issues with complex shaders being attached to the hair, I wonder whether we have a new Octane shader which would have typical hair values, like spec etc. I would like to keep in the random colour value though.
Oh, and it would be cool to have the dynamic hair update in the preview window.
Is there a way to have motion blur in the preview window?
Batch rendering to check the amount of blur takes a fair bit longer to render - I think someone said that several frames get rendered in batch, when motion blur is on.
And good work on maintaining the overall tone from the maya window to the saved .exr. Octane standalone creates a darker version once saved as .exr.
Same goes for no cap on the depth. Cheers for that.
The other things are the limited region rendering. Sorry, but I can't see where to activate this in the camera?
And exporting as alembic from the pipeline menu is ok, but exporting as an Octane alembic crashes maya (2015).
Oh, and a separate note, does changing the priority to high, use more or less of the GPU? I could never figure this out :oops:
And one more thing :D, what are the virtual materials in the shader?
Cheers again.
Steve
Wenneker
The virtual material is explained in this thread:
http://render.otoy.com/forum/viewtopic. ... 8&p=182544
prodviz
Sweet, cheers Wenneker.
sirenesoong
Thanks JimStar!!!! :)
Q6600, 8 GB ram, Geforce480
Return to “Autodesk Maya”
