OctaneRender® for Maya® 1.55 - 3.7 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2014 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 359€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
Installation:
DOWNLOAD
OctaneRender for Maya - v3.7 Linux (13.5MB autoinstaller file)
Yours,
The OctaneRender™ Team.
matrix2012
Hi JimStar
not create in linux.
but create windows and then open it in linux.
linux to windows everything is ok.
Best regards
matrix2012
Yes, have reproduced it. Will check it. Thank you.
EDIT: As quick-workaround - you can use Maya's ASCII format, it works just fine in this case... It is something with binary format is broken between Win and Linux versions. I'm checking it...
matrix2012
Hi JimStar
Thanks for your hard work.
Best regards
matrix2012
Next version HERE.
Return to “Autodesk Maya”
