OctaneRender® for Maya® 1.55 - 3.6 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2014 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 359€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
Installation:
DOWNLOAD
OctaneRender for Maya - v3.6 Linux (13.5MB autoinstaller file)
Yours,
The OctaneRender™ Team.
matrix2012
Hi JimStar
The problem is still there Windows to Linux.
Octane Render for Maya 1.55-3.6 Linux and Windows machines have the same version as Maya 2014 SP4.
sorry for my bad english.
Regards
matrix2012
matrix2012
Hi JimStar
you can further help me with the problem?
Best regards
matrix2012
matrix2012
I can't reproduce it. I've created the scene in Linux, changed the shader color, saved it. Then opened in the same version in Windows - all is OK, the shader color is the same...
Next version HERE.
matrix2012
Hi JimStar
not create in linux.
but create windows and then open it in linux.
linux to windows everything is ok.
Best regards
matrix2012
Return to “Autodesk Maya”
