Stops while rendering
coilbook
Does anyone know what this means. We render in 3ds max and octane jsut stops Thank you
Started logging on 08.07.14 16:49:10
OctaneRender version 2.00 (2000010)
CUDA error 700 on device 0: Error code unknown.
-> Kernel execution failed (dl)
CUDA device 0: Direct lighting failed
-> Failed to deallocate device memory
-> Could not get memory info
3dgeeks
Does it also happen with a small scene. it could be that you are out of memory
coilbook
I see. Thank you. In octane preview it says it uses 1.4 Gb of 3 available. Maybe it uses more during render. Would be nice to get data like this during render as well
I left PC render over night and it restarted itself(1200W PSU Corsair). Seems like it just cannot render more than 3-4 hours something always happens.
And this is what windows log said not sure what it is
The process C:\Windows\system32\svchost.exe has initiated the restart of computer on behalf of user NT AUTHORITY\SYSTEM for the following reason: Operating System: Recovery (Planned)
Reason Code: 0x80020002
Shutdown Type: restart
coilbook
read somewhere maybe windows update restarted my pc without my permission. But it is windows so i am not surprised
Karba
coilbook wrote:read somewhere maybe windows update restarted my pc without my permission. But it is windows so i am not surprised
It happened for me several times. I had to disable these updates.
coilbook
Thank you!
mvscommon
Try to set "refresh time" to 1000ms. This is helps when you get gpu drivers crush during render.
coilbook
Thanks.
coilbook
Still does at around frame 30 just stops
Started logging on 10.07.14 15:42:04
OctaneRender version 2.01 (2010000)
-> Failed to unload module
and cannot use 2.02
because of this
coilbook
mvscommon wrote:Try to set "refresh time" to 1000ms. This is helps when you get gpu drivers crush during render.
I am trying to increase refresh time to 1000
Could you tell me what is refresh time? Manual does not mention anything
Thank you
Return to “Autodesk 3Ds Max”
