Total time changes instantly.
- MaTtY631990
I understand that a lot of processing is going on in a scene and it is try compute a lot of complex lighting and materials in the scene and you can't of course ignore the slight increases in render time, but even when rendering for say 1 minute to a few minutes the render time dramatically increases sometimes in a scene. Anyone else experienced this problem. I have never seen this problem in earlier releases of the plugin.
Do you use displacement or PMC?MaTtY631990 wrote:I understand that a lot of processing is going on in a scene and it is try compute a lot of complex lighting and materials in the scene and you can't of course ignore the slight increases in render time, but even when rendering for say 1 minute to a few minutes the render time dramatically increases sometimes in a scene. Anyone else experienced this problem. I have never seen this problem in earlier releases of the plugin.
- MaTtY631990
I do you PMC, of course better in a lot of difficult situations. Also I do not use displacement.
