Multiple camera position saves
JNDesign
Hi Paul
Is there a way to save multiple camera positions with in the plugin?
Many thanks
If you create a new 3D view, you can save the rendertarget to that view, so that effectively allows the camera position to be saved (just activate that view to enable that camera angle).
prehabitat
face_off wrote:If you create a new 3D view, you can save the rendertarget to that view, so that effectively allows the camera position to be saved (just activate that view to enable that camera angle).
Once the rendertargets have been saved can we use a lau script to render them one after another?
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
Seekerfinder
Good idea prehabitat.
If you export each camera angle to ORBX or OCS, then yes, you could each in Octane Standalone. You would need to write some LUA for Standalone to load, render and save each ORBX.
Return to “Autodesk Revit”
