OctaneRender® for Maya® 1.55 - 3.5 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 359€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Fixed broken displaying of textures in viewport and UV-editor.
  • Fixed sunset color bug.
  • Minor fixes and improvements...
DOWNLOAD
OctaneRender for Maya 1.55 - 3.5 (28.8MB autoinstaller file)
OctaneRender for Maya 1.55 - 3.5 Demo (26.7MB autoinstaller file)
Yours,
The OctaneRender™ Team.
prodviz
Awesome, cheers Jim.
Slimshader
Nice thanks!
Vyoor
Wow!
Thank you JimStar!
Now SunSky works perfectly :)
Can't wait for 2.0 ;)
Cheers!
i7, 4x GTX 780, Maya.
matrix2012
Thank you for all of your hard working JimStar :)
p3taoctane
Upon loading PLugin
AutoLoad selects... Loaded does not
Been using the previous version o problem for weeks...
Standalone 1.5 and 2.02 both load and run with registered authorization
Get error
//Error: Unloading Octane... //
//Error: Line 1: initializePLugin function failed (OctanePlugin) //
//Warning: line 1: waitCursor stack empty
Any ideas
p3taoctane
I removed all my prefs
Reloaded plugin
choosing loaded first.... then autolaod and it worked
all good
churumbela
I'm currently in the middle of a rendering process and I'm stucked with a strange error.
Batch render starts normally and indicates to be rendering each frame as usual. However, no file is written afterwards.
The maya render log shows this:
Error saving frame x ("png" image to "(my folder structure)"): (kFailure): Unexpected Internal Failure
it does so for every frame and it doesn't indicate anything else.
Any help will be much appreciated, since these renders are due quite soon.
(I'm using render layers, dunno if it has something to do with this).
thanks!
churumbela
I think it may be something with the save-path itself - perhaps access rights to folder for batch process... I can't say more precisely without having the scene... But it is unlikely that render layers are the reason: your issue appears already on the rendered image saving stage.
Did you try different paths and/or file names to save the images? Did you try different image types (including .exr)?..
churumbela
Hi JimStar, thanks for your quick response!
the full error says:
ERROR, Cannot open file C:/Users/etc/filename_0010.png; ensure that it exists and is of type "PNG"
ERROR, No more internal memory
Error: line 0: Failed to open output file: C:/Users/etc/filename_0010.png
Error: Octane: Error saving frame 10 ("png" image to "C:/Users/etc/filename_0010.png"): (kFailure): Unexpected Internal Failure
I've created a test scene using renderlayers and saving images to the same path and in the same PNG format and it worked, so you're right, render layers are not the problem, but also isn't the file format nor the file path.
I've tried rendering the original scene in another format with no luck.
The "no more internal memory" message makes me think maybe it has something to do with the very large textures I'm using?
gonna try downresing them to see what happens.
Return to “Autodesk Maya”
