im updating the driver now but other than that is there anything i need to do for 2.0 to see the video cards, i just purchased the standalone and poser plug in upgrade, installed, things seem fine - shows 2.0 etc... but no video card showing
i installed Octane Stand alone in the default Dir, should I also uninstall the old stand alone version?
thanks
2.0 not seeing CUDA devices
Installing the plugin is enought. No need for the stand alone installs. (You do need both serial numbers when activating)
The new video drivers are required. 2.0 won't run with the older drivers
Which video card(s) do you have?
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
Titan - primary
and
770 - mostly used fro OS but will use both for smaller renders
and
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
yep worked, i did have a driver higher than required but loading new one solved issue thanks
