Strange error log - no render-
mbetke
I got a strange error logging.
Any hints? I have enough GPU memory free. No funcky materials. Only .jpg, .png.
Started logging on 25.06.14 15:33:12
OctaneRender version 2.00 (2000010)
CUDA error 1 on device 1: One or more of the parameters passed were not within an acceptable range of values.
    -> Failed to bind texture to device memory (data5)
CUDA device 1: Failed to bind data texture 4 of context 0
CUDA error 1 on device 2: One or more of the parameters passed were not within an acceptable range of values.
CUDA device 2: Failed to bind data texture 4 of context 0
CUDA error 1 on device 3: One or more of the parameters passed were not within an acceptable range of values.
CUDA device 3: Failed to bind data texture 4 of context 0
CUDA error 1 on device 0: One or more of the parameters passed were not within an acceptable range of values.
CUDA device 0: Failed to bind data texture 4 of context 0
PURE3D Visualisierungen
mbetke
Sees it has something to do with a RailClone object. Only 5million tris but causing trouble even if I trun it into a editable poly.
Karba
mbetke wrote:Sees it has something to do with a RailClone object. Only 5million tris but causing trouble even if I trun it into a editable poly.
what is your overall triangles number statistic?
Return to “Autodesk 3Ds Max”
