I have create a lua script that can load meshes and insert them as instances . It was working until version 2.00 . Now for some unexplaind reason it stops.
Here is the script
Load a scene as instances - problem
- Attachments
- Load Instances.lua
- (4.73 KiB) Downloaded 357 times
- Mithrandir
Hey gmillas,
Looking at your code you have the line:
The getSelection() function returns a table.
So later, your code reads:
The findItemsByName() function needs to be called by a "graph" type object.
cursel is simply a table with no methods attached. What you want to do would be:
Then of course you will actually need nodes named GROUP and GEOM_OUT.
Happy coding.
local cursel = octane.project.getSelection()[1]So later, your code reads:
parent=cursel
group= parent:findItemsByName("GROUP")[1]
print(group)
meshout=parent:findItemsByName("GEOM_OUT")[1]
print(meshout)cursel is simply a table with no methods attached. What you want to do would be:
local cursel = octane.project.getSceneGraph()Happy coding.
Thank you for your response .
but as you can see the [1] takes the first selected out of the table
local cursel = octane.project.getSelection()[1] <- this
and my problem is not here
the problem starts when i check for the parent owned NT_IN_MATERIALS for existance by name
and more specific when i try to add new NT_IN_MATERIALS to the parent that are not inculed ...
if i have a fresh GT_STANDARD node just created by the the script and thus no NT_IN_MATERIALS exist , the script works well.......
Any ideas?
Any ideas?
Finding nodes by name has always been a bit problematic, it's probably better to search for the nodes by type instead. I'm unable to really test your script because I don't have the instance file and all the other files behind it. Do you get any kind of error message?
- Mithrandir
Sorry gmillas,
when I first tried run the script, I didn't have a file for defining objects and transforms
so it failed with the cursel when I bypassed the file lookup code and mistakenly assumed
octane.project.getSelection()[1] would be for a render target as in so many other scripts.
A whole mess of objects were scattered about, pretty cool, and so I thought that may have been
the problem. No, my head hurts and more in-depth study is needed when I have time.
