Hi Karba,
Turbosmooth has a render iteration option that doesn't refreshes automatically in octane viewport when you increase or decrease the value of render iterations render. Render in octane viewport refreshes only if i switch off, and then switch on turbosmooth modifier. Is this a limitation or a bug ?? it would be great if this worked.
I also noticed in 2.0a version that there always is a shadow terminate issue with low poly meshes ... a box or a sphere with a turbosmooth applied to it, needs an value of 4 to avoid artifacts in shadows ... Is there any chances to solve this issue in futur ?
Regards.
"turbosmooth"
- MistAjuliax
Win 10 pro 64 / GTX 1070ti, gtx 1070 / FX8320E / 16Go DRR4
- MaTtY631990
No bug/limitation, all you need to do is just set your object to movable proxy to see any changes automatically.
- MistAjuliax
Hi, thanks to reply.
So i was talking about "turbosmooth render iteration" and not just "iteration", iteration both subdivides the mesh in 3ds max viewport and in the frame render, when render iteration only subdivides the mesh at the render, and then with octane, it subdivides the mesh only in octane viewport and not in the quadview. this saves lots of fps for a best feedback. I had an answer, and this fonction is actually under developpement.
Regards.
Regards.
