I played around with the random color texture but only found a C4D setup here which I don't understand.
I would like to give variations to vegetation. The leaves.
random Color Setup?
PURE3D Visualisierungen
it only works with different objects right now, not with elements on the same object.
put a otane gradiend in texture slot, and put a random color in input of the gradient.
add desired colors to the gradient and you have your object colored randomly.
hope this helps
hope this helps
Core i7 860, ZOTAC GTX 580 - 3GB, 2 x GTX TITAN, 32Gb RAM
- voltaire585
Another option that works, is in diffuse texture choose Gaussian Spectrum
In wavelength Choose Random Color Texture
Set Width to 0.05 and power to 1. (can adjust as necessary)
