I must be going insane. I don't see a "support" link or any way to report a bug.
The new version has several bugs.
If you load two meshes (or any nodes for that matter) and then delete (with keyboard delete or right click delete) them from the node explorer you get
a "R6025 pure virtual function call" Runtime Error! and then immediately crashes. However if you reproduce the scenario and delete from the graph editor it works fine.
Also the maximize icon (the one in the top right corner) does nothing. Seems trivial, but I'm constantly jumping between monitors (one is larger than the other). would
be nice to simply maximize the screen to fit instead of dragging the corners around.
Is there a way to set the default daylight to my locale and time? Would be nice
to be able to open various files and show shadows without having to adjust every time I reload.
Also had a problem with the texture node, but can't recreate it, may have been related to first issue.
Good Luck
James
Bug Report?
Hi James,
Thanks for the bug reports.
This is a perfectly fine place to report bugs, there are a number of us that keep an eye on the forum including the dev's so rest assured reports here get seen.
Also you can use [email protected]
Chris.
Chris.
