Network animation
jan kudelasek
Hi Karba,
I tried animation with network, but max render window show and save samples from master only,so render saved from max render window is more noisy then from octane render window.
When I wanted to use slave machine as single again, i stopped deamon, but octane rendered only some parts of geometry.
Jan
W7 / Quad Core Xeon E5405 / 24G / Asus ENGTX 480, 580 / http://www.allcity.cz / https://www.facebook.com/pages/Allcity/ ... e=bookmark
Karba
jan kudelasek wrote:Hi Karba,
Jan
Hi Jan
What is the render time of a single frame? Do slaves have enough time to join the render process?
jan kudelasek
render time 3 min. 220 samples...yes they have i think.In the octane render window I noticed that they joined after cca 1 min. . Render time of single frame was quite same in both render windows. But frame from max window was very noisy, like computed on one card.
Karba
jan kudelasek wrote:render time 3 min. 220 samples...yes they have i think.In the octane render window I noticed that they joined after cca 1 min. . Render time of single frame was quite same in both render windows. But frame from max window was very noisy, like computed on one card.
Please show both renders.
jan kudelasek
ok,I will show tommorow, I´m not in the office now.
Karba
jan kudelasek wrote:ok,I will show tommorow, I´m not in the office now.
ok, I can reproduce the issue.
abstrax
Sorry, that was my bad. The slaves are actually rendering and returning the results, but they are discarded and not integrated into the final result that is passed to the plugin. I have a fix for this problem, which is on the slave side. How urgent is the problem?
nildoe
Hello,
A bit off topic but it pertains to net render, does the scene have to fit in slave's memory as well? or Octane just use the cores of the slaves to aid in render? (that would be so cool)
Example: can i have a scene that is 4gb in size to render on master with a titan for example, but have slaves on gtx590's to use their cores to aid in render speed?
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
Karba
nildoe wrote: A does the scene have to fit in slave's memory as well?
Yes, it does.
nildoe
Hi Karba,
ok thx for the reply. :).
Nildo
Return to “Autodesk 3Ds Max”
