OctaneRender® for 3ds max® v2.0a
Karba
Main changes since version 2.0
  • Network rendering fix.
  • Sky texture in daylight.
  • 3dsmax 2015 support.
DOWNLOAD
Installer http://www.refractivesoftware.com/plugi ... p_2_0a.zip (25MB ZIP File)
Yours,
The OctaneRender® Team.
tonycho
Hi Karba thanks for update
do you have manuals for this new 2.0 features in 3dsmax? :D
thanks
http://www.antoni3D.com
Win 7 64 |GTX 680 4 Gb (Display) | 3 x GTX690 4Gb | Intel i5 |Corsair 16GB
Chris
Does the Sky texture in daylight actually work? When I connect an environment map with a rgb texture nothing happens.
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
Karba
Chris wrote:Does the Sky texture in daylight actually work? When I connect an environment map with a rgb texture nothing happens.
You have to connect rgb texture directly.
HHbomb
Anybody succeed in network rendering ?
lixai
@HHbomb in order to render on network you must have a second license for octane, do you have that ?
Core i7 860, ZOTAC GTX 580 - 3GB, 2 x GTX TITAN, 32Gb RAM
HHbomb
yess lixai :mrgreen:
do you succeed ?
the Deamon slave don't seem to see the master.... even with firewall off.
In main window there is IP adress of the slave, name and status are "unknown"
I suspect the install don't work because octane version is still 2.0.7a...
Karba
HHbomb wrote:yess lixai :mrgreen:
do you succeed ?
What octane version number do you see in 3dsmax panel?
lixai
do you succeed ?
i don't have a second license :cry:
HHbomb
oooops Karba, I didn't see that the installer is by default installing 2015 version....
now IT WORKS !!!!!
:o :shock: :o :shock: :o
master alone = 3M sample /s (1 titan)
all computers : 1 titan + 4 titans + (3 580 + 1 590) = 30M sample /s...++
Thanks Karba !!!
Return to “Autodesk 3Ds Max”
