COctane article+video
pzdm
Hello AOktar
I would like to inform you I started your plugin review here:
http://www.3dsoftware.cz/3dportal/clanek.aspx?id=1967
A new article will come soon and it will be published on our most important CG server www.grafika.cz as well
I´m really happy I got a suitable GPU and have an opportunity to test it.
If I can, here is my wish list, i hope I´m not wrong,just I´m not an Octane expert :)):
If you turn off a color channel, it activates it instead
If you place a texture load an effect over the texture, it´ s not automatically loaded inside (sometimes, several shaders support the feature) ImageTexture is a good example.
IS possible to change a default/turn off Environment. Just stay pure black?
Is possible to export a whole scene to StandAlone? It exports materials only to me
No worries, I did not mention it :), because is possible I´m wrong
Pavel
atome451
Yes, it is possible and it works fine. You need to refresh your scene in the Octane previewer (when you refresh the scene, it recreates the node structure). In this case, when you save as OCS or open in standalone, it creates the necessary .OBJ files and nodes.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
