OctaneRender® for Maya® 1.55 - 3.0 Win [OBSOLETE]
This is the test release
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 359€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Big plugin's refactoring as preparation to ongoing 2.0 engine usage (therefore it is released as "test" so far). Report please if you will get some issues, I will fix them as fast as possible.
  • New 1.55 engine.
  • Maya 2015 support added.
  • Octane light-sources are improved.
  • Mesh visibility attributes are added. You need to understand, that this will work only for non-Global meshes (Octane engine is not able to hide some parts of one mesh object, the whole object only).
  • Some improvements in materials conversion feature.
  • A lot of minor bug fixes and improvements...
DOWNLOAD
OctaneRender for Maya 1.55 - 3.0 (28.5MB autoinstaller file)
OctaneRender for Maya 1.55 - 3.0 Demo (26.4MB autoinstaller file)
Yours,
The OctaneRender™ Team.
cyrillweiss
Thx Jim
HW01:WIN10x64/X79/i7-3930K/64gb/GPU:1xTitan X, GTX 1080ti, SW:Maya2018/2019, Cinema 4D R20
HW02:WIN10x64/Z370/i7-8700K/64gb/GPU:1xTitan X, GTX 1080ti SW:Maya2018/2019, Cinema 4D R20
etc. ...
prodviz
Awesome stuff, cheers Jim.
Digitaline
Hiha, thanks Jim !
But there is no support for Maya 2012 ? Can you tell us if it will be planned for future stable releases and for the upcoming 2.0 ?
If not we'll have to upgrade all our Maya licenses... :|
sirenesoong
:) thanks jim!
Q6600, 8 GB ram, Geforce480
Digitaline wrote:Hiha, thanks Jim !
The plugin supports 4 previous releases, so when one is added on top, one is dropped from the bottom. Support of such amount of different backward compatibilities (moreover, for different OSes and architectures each) spreads the the work forcing me to write and test a lot of different code for the same functionality, special to every ancient Maya version, before releasing of every new version of plugin.
Moreover, especially the border between Maya's 2012 and 2013 had some important differences that restricted a lot of plugin's functionality in 2012, forcing me to add some ugly workarounds to achieve what was gracefully done in 2013 and later...
So, if you do not have some special need to stick to 2012 - I advice you to move to some newer Maya version or use the previous stable plugin's version...
Vyoor
Thanks JimStar for Your work!
I have found first issue.
It seems that sun direction is not working. From the beginning it's fixed in non vertical position.
Is it possible to add support for camera motion blur in this relase?
i7, 4x GTX 780, Maya.
Vyoor
Thanks, I will check it.
prodviz
Hi Jim,
the sphere light renders fine, but when I try the plane light, I get the following error:
// 0:00 Octane engine: creating meshes... //
// 0:00 Gathering Mesh objects data... //
// 0:00 ...done, //
// 0:00 Gathering Subdiv objects data... //
// 0:00 ...done, //
// 0:00 Gathering Octane Light objects data... //
// Error: Octane: error allocating the memory for Object "octaneLight1" //
// Error: Octane: Error mesh export. Octane render stopped. //
cheers,
Steve
solomon
THANK YOU!!!! off to test the texture conversion update ~ that's the one feature, to me, that really needed an major update
Solomon W. Jagwe
Return to “Autodesk Maya”
