OctaneRender® for 3ds max® v1.53
Karba
Main changes since version 1.50a
  • scene load crash fix.
  • slow geometry preparation fix (new option "use objects render settings" is switched off by default).
  • Background image (used the same image as for 3dsmax viewport).
  • Camera motion blur duration.
  • Exporter to Standalone.
  • Render setting UI restructure.
DOWNLOAD
Installer http://render.otoy.com/plugindownloads/ ... p_1_53.zip (25MB ZIP File)
Yours,
The OctaneRender® Team.
BKEicholtz
Thanks, Karba. If I build my scene in Max, including iToo ForestPack instances, then export to STANDALONE, will they remain efficient instances?
I am wondering if we are close to the time when I can build my scene in Max, then export to STANDALONE, then render in the CLOUD. Thanks again.
ASRock Extreme11 | i7 3970x 5.0 Ghz | 32gb RAM | (4) EVGA SC Titans
Karba
BKEicholtz wrote:Thanks, Karba. If I build my scene in Max, including iToo ForestPack instances, then export to STANDALONE, will they remain efficient instances?
Everything will be exported.
Elvissuperstar007
Export does not work
Karba
Elvissuperstar007 wrote:Export does not work
Any details?
Elvissuperstar007
Any details?
max 2014
1)created animation
2)export push, nothing happens
No export file
Karba
Any details?
max 2014
1)created animation
No export file
did you setup export folder?
did you check for orbx file in this directory?
Dom74
Any details?
max 2014
1)created animation
No export file
Same here, nothing exported, no file in directory, tried with both std. and octane cameras.
Win7 x64 - 3DSMAX 2019 - 32GB RAM - 1080 TI
Karba
Ok, got it. Will fix in a few minutes.
Dom74
Return to “Autodesk 3Ds Max”
