Hi
I was trying to look for what "texture in" node means on the forum, but I can't get to search quotes.. What is the expression/method? Been looking around on help with no succes
search quotes on the forum
Texture in will create a texture pin node on the "outside" of the node graph. Useful for tweaking your materials from "outside" or passing a texture to a node that "does some work on it".
Searching for forum phrases works, but it wont produce useful results if you have such common words like "texture" and "in"
cgmo.net
cgmo.net
- waterthinking
Thanks for the explanation. And so what would be the expression to use for a phrase? "...." ??
