Show materials in viewport
Ibon_83
Hi Octane forum friends. First of all, I apologize if this question has been asked before.
My question is: Is there any way to show all materials in viewport (textures and/or colors) after octane material conversion?
I use to apply V-ray materials to my geometry, and when i want to make a render with Octane, after material conversion everything becomes white. I have to go to all materials one by one and activate "Show shaded material in viewport", and i was wondering if there's an easier way to do it.
I have tried with material editor's menu (Material --> Show Materials in viewport as --> Shaded materials with maps) but it doesn't work, everything stays white. Btw, i'm using 3DsMax 2014
Thanks in advance for your help!
akira
run the attached maxscript in max :)
-- show texture map in viewport for all octane diffuse and glossy materials
-- supports viewport display of RGB Image, Alpha Image and Greyscale Image
fn get_texture_map tex_map=
	if classof tex_map == RGB_Image or classof tex_map == Alpha_Image or classof tex_map == Greyscale_Image then
		return tex_map
	else if classof tex_map == Multiply_Texture or classof tex_map == Mix_Texture then
		if tex_map.texture1_tex != undefined then return get_texture_map tex_map.texture1_tex
			else if tex_map.texture2_tex != undefined then return get_texture_map tex_map.texture2_tex
	return undefined
for ii in SceneMaterials do
	if classof ii == Diffuse_Material or classof ii == Glossy_Material then
		if ii.diffuse_tex != undefined then
			jj = get_texture_map ii.diffuse_tex
			if jj != undefined then showtexturemap ii jj on
also you can disable texture showing by changing the "on" to "off"
showOctaneDiffuseMap.zip
(519 Bytes) Downloaded 304 times
BKEicholtz
This is very helpful, thank you. I did not know this was possible.
ASRock Extreme11 | i7 3970x 5.0 Ghz | 32gb RAM | (4) EVGA SC Titans
HHbomb
Thanks a lot.
Hope otoy give us more access to Scripting !
coilbook
i have same problem with Mix materials they are all pure black in 3ds max viewport because octane does not have an option yet. I hope they will add a button
acc24ex
nice one..
Ibon_83
Many many thanks my Akira!!!
Return to “Autodesk 3Ds Max”
