I noted that acutally OCTANE don't render instances.
That's very sad expecially with complex scenes that need instances for duplicated objects.
Is this on "to do" list, or is a bug? And when, if is on the "TO DO" list, will be updated? Could possible in the next update of the plug in? To create a FOREST i must use CLONES now, but clones have evident limitations.
thank you!!!!!!!!!
INSTANCE are not rendered
http://vimeo.com/user2509578
Nearly all is done for a release candidate, but i have found a problem with instances and my motion blur implementation.
Don´t know if i should fix it first or after a release.
Will first take a fast look, maybe the problem isn´t heavy...
face
face
