Octane Override on Modo 801 doesn' work
Lobito9
Hello,
Octane Override on Modo 801 doesn' work.
Also when Shader Tree->Add Layer->Custom Materials->Octane Override, there isn't such Octane material.
I'm OctaneRender_for_Modo_701_1_52_0_64_beta_64bit.
Thanks.
This does provide much info. Does the Octane Override item get added to the shader tree? Is there an error message? Is there anything in the Modo Event Log?
I wuld have thought it not possible for an Octane Override item to NOT be added to the Shader tree, and there not be some sort of error message. If you click Add Octane Ovrride from the OctaneRender Setup panel, do nodes get added to the Schematic of that panel? Can you pls check the Modo Event Log and Octane Cuba log for errors?
Lobito9
Hi Paul,
Thanks for answering.
Clicking on override buttom get a error message 'create shader > failed'. In Shader Tree , in costum materials there is no octane material to choose from.
Already re-install Modo Plugin twice. This happen after i upgrade from Octane 1.51 to 1.53. Already downgraded but it still fail.
Regards.
Carlos
Hi Carlos.
1) Is Octane Standalone working for you?
2) Did the plugin work with Modo701 on that PC?
3) What cuda drivers do you have installed
4) What other Modo plugins do you have installed?
Lobito9
Hello Paul,
1) Yes, both 1.51 an 1.53.
2) Yes.
3) GTX 680 with the latest driver 335.23
4) HDRLS, SES 1 and 2, PAD, PACK and XSR
Thanks.
Carlos
Hi Carlos
I've had no other reports of this problem, and I've never seen it before - so my apologies for not having an immediate answer.
Can you pls try disabling ALL other plugins and then trying to add an Octane Override.
If you get "create shader > failed" can you pls post you Modo Event Log.
Lobito9
Hi Paul
With all other plugins disabled it stil fail.
Here is the Modo 801 log:
-- modo Event Log -- Mon May 05 17:58:50 2014
System -------- Time -------------------- Type -- Message -------------------------------------
Log System Mon May 05 17:56:46 2014 Info Log system started
octaneRenderFor Mon May 05 17:57:21 2014 Info Authenticating Octane: Complete
octaneRenderFor Mon May 05 17:57:21 2014 Info No Normal map found for mesh [Mesh]
Progress Monito Mon May 05 17:57:21 2014 OK Loading Geometry into Octane [0,00 s]
Commands Mon May 05 17:57:31 2014 Failed shader.new failed
Commands Mon May 05 17:57:31 2014 Abort shader.create: Abort
Carlos
Thanks Carlos
Can you pls try deleting your Modo801.cfg file and then try adding an Octane Override.
If that does not work, can you pls start a new Modo scene, add a cube, then try to add an Octane Override to the cube material (which should fail), save the lxo and post the lxo in this thread.
Lobito9
Hi Paul,
Now its working on 1.53.1.65
Enable one kit at time and its working with all kits.
Before (with OctaneRender for Modo 701 1.52.0.64 beta (64 bit)), deleting modo801 config and with all kits disabled, it still didn't work. Must be something to do with the plugin.
Anyway, thanks for your help.
Carlos
Glad you are up and running Carlos. I suspect it might have been an incomplete installer download - since there were no other reports of this.
Return to “Foundry Modo”
